Best ariel please?
Darren226
Hi I'm a truck driver using a Thunderpole T-1000 with a DV27 on the original Daf mount which is behind the cab so the Arial is in between the cab and the trailer it's a super space cab so the original Daf Arial was lower than the roof hence why I changed to the DV 27 which is slightly higher than the roof the range I get is about 3 miles is there a better Arial I could use or should I stick to this the rig output power is just over 10 watts (radio was tuned in Italy) mainly use AM any advice appreciated thanks.
Hi Darren,
i would suggest checking your SWR on your antenna Darren DV 27s are good antennas but most truckers go for the orbitor Antennas as they are flexible with good performance gutter mount at the rear of the truck would be a great place to lower the SWR link for the gutter mount http://www.thunderpole.co.uk/gutter-mou ... t-kit.html & for £10 for the fittings & cable you cant go wrong buddy or a mirror mount http://www.thunderpole.co.uk/mirror-bar ... t-kit.html
Darren226
Thanks wildfire the SWR is just under 2 across all 40 I've checked the grounding and that's ok can't use a gutter mount on these new Dafs as fibreglass roof comes right down into it and the mirrors are different too I think I might try a flat bar mount on the back of the side wind deflector and fit my sirio megawatt 3000
hi Again Darren i have had a look at the new dafs & all the mirrors are a like thankfully & your all good to go with the following http://www.thunderpole.co.uk/mirror-bar ... t-kit.html & for £25 you cant go far wrong as it comes with the so239 fittings & coax as well for your sirio megawatt 3000 as like most mirror arms this mirror mount will hold on to any mirror from 18mm up to 35mm plus the bar mount your talking about only holds 3/8 antennas buddy :wink: one way or another we will get you there :lol:
Darren226
Think I'll have a look in Italy see if I can get a mount that will bolt under the sun visor. The top of the mirror arm is flat and plastic and placing on the bottom would be to low and leave it to easy to steal (east European truck drivers) on the old Daf 95 a mirror mount was ideal as well as a gutter mount but the 105 and 106 are different. I really appreciate your advice though and has got me thinking of other options thank you.
hi Darren,
i was also thinking about this one for you buddy i know it says it is for hatchbacks & boot mounts but something i did learn about this one is it also can be fitted on to the frame what goes around the drivers door for your sirio antenna & can come complete with fixings & cable or maybe a mag mount http://www.thunderpole.co.uk/magnetic-m ... large.html with a swivel adapter http://www.thunderpole.co.uk/mounting-a ... aptor.html so you could mount your mag mount to the rear of your cab & with the swivel adapter you could straighten your antenna as much as it would go i have seen this done on trucks when i was driving a Volvo globetrotter & thinking to myself now why didnt i think of that idea #-o a couple of more ideas for you buddy
the best antenna to replace the daf one if you cant fit a guttermount over the drivers door is the red devil but tye it at the top as it tends to swing about and ruin the mount witch is not easy to change. the daf antenna is wide banded just in the wrong place and is a good antenna. The orbiter picks up far too mutch reflection from the cab and you will not be able to swr it
Darren226
Thanks Stampman I've got plenty to think about now!
bloody truck manufacturers never seem to think about drivers using cb radios & where to put there antennas :roll: sigh
