TTI TCB660
TheFarrier
CB Handle: Blacksmith
Hello all, new to to the game and I'm looking for some advice.
Just yesterday I bought a tti tcb660 cb radio, a (other company) tornado stinger aerial, and a (other company) turbo mag mount.
Iv all the gear set up in my van, I've the radio set to AM which is the norm in Ireland, and I've managed to communicate with a friend up to range of about 2-3 miles ( we were both home by then so no chance to test any further).
Iv been on the motorway most of today on channel 19, the truckers channel, but I haven't managed to pick up anything all day.
I set the squelch to as close as I could to correct, but all I get is the odd burst of static/interference/I don't know what.
Any help, advice or tips greatly appreciated.
Hit it with a stick and see what happens!
When in doubt, FLAT OUT!!!
hi Stephen,
if the tornado stinger aerial is 1.55 metres tall i don`t understand why it is not performing right for you buddy any antenna what is shorter is not actually not worth looking at let alone buying lol you should have got a SWR meter with your equipment to check your SWR on your antenna that could be the problem here is what you will need to check you SWR with a patch lead http://www.thunderpole.co.uk/swr-meters ... r-420.html
also with it also been called the tornado stinger the original antenna is from thunderpole & is called the orbitor but other companys made copys of the antenna what don`t perform the same & when a original orbitor bends by a low bridge or tree it springs back straight up with out looking bend but the copys remain bent & out of shape but what i would do is to first check the SWR & let us know what your SWR is buddy then we can try & help you out more & give you more advice if we can :wink:
TheFarrier
Great, thanks for the reply.
A mate at home has a SWR metre, ill have crack at it the weekend, must get a patch cable.
Thsnks
TheFarrier
If I have the squelch set correctly what should I hear?? Static/hissing or nothing at all??
each person sets the squelch to his own setting i personally run with a permanent hiss cause im a nosy sod and dont want to miss anything
MrFendt
Hi, I have an albrecht ae4400 radio, as far as I know, the radio is German, as i cannot find much info on it in English, will this work here in Ireland ? I'm new to cb and not sure about different areas, it does work, as I was talking to a man in hamburg Germany, through skip, and it was as clear as day.
MrFendt
If and when we arrange a time for us to go on the air, put your squelch all the way down (constant hissing) that will give us the best chance of hearing each other.
TheFarrier
Will do lad.
On a general note, a hooked up to an swr meter at the weekend, and it seemed to be reading a little high.
On channel 1 it was around 2.75, on 40 it was 3.
How do these figures seem to those of you that know more than I do about this stuff??
Thenks
yes definately high needs trimming to bring the swr down to about 1.5 for best results
