Hello as you can see I'm new here! Have done a search but not come up with anything.
I was wondering if it would be possible to use my existing car ariel (incorporating a switch) to use it for my CB as well as I'm thinking of purchasing one.
I don't want to spoil the look of the small van and I don't have gutters etc. to use non body drilling mounts.
I know I can do it in practise, but will it be practical for signal etc.
Cheers, Oz
Using Existing Car Aerial for CB Use
sorry unless the antenna is made for cb then you can not use it as such there use to be a cb antenna you could also use for radio made byb antenna specialists in the usa but have not seen one for years
Ah I see, yes I remember this aerial, seen it somewhere on the internet before.
Maybe I could use the current aerial mount to mount a CB Aerial and see if the radio might work off the CB aerial, I can't see it damaging it but if I'm wrong please do correct me!
Or have a look at this http://www.thunderpole.co.uk/sirio_triflex.html
