Best ariel please?
Hi I'm a truck driver using a Thunderpole T-1000 with a DV27 on the original Daf mount which is behind the cab so the Arial is in between the cab and the trailer it's a super space cab so the original Daf Arial was lower than the roof hence why I changed to the DV 27 which is slightly higher than the roof the range I get is about 3 miles is there a better Arial I could use or should I stick to this the rig output power is just over 10 watts (radio was tuned in Italy) mainly use AM any advice appreciated thanks.
Johnny Mac
Yes a Sirio Performer 5000. You can swivel it to 90'. I use one on my Volvo and its really good. I've got out over 10 miles on mine across London using a 4 watt radio.
You may need to get a different mount as I think Sirio use their own type rather than a 3/8. If you have a Ariel already through the cab it should be easy enough to fit.
I put a photo of it on another thread a few weeks back.
