midland 98 plus static noise.
Hi I'm new to this forum and not really clued up on cbs. I just bought my 98plus and fitted it to my wagon today with a new midland lc59 antenna and mag mount. Problem is every 8-9 seconds I get a 1 second blast of static noise even with the squelch right up. Does anyone know the reason this maybe? Thanks in advance.
the hardest thing to find is static interference the only way is to remove the fuses one by one till it goes away then you know what area you are looking in for it ie: what does that fuse power
hope this helps
hope this helps
