Absolute beginner, advice please?
akewstick
Hiya all, I want to be able to reliably talk to someone who lives 0.7 miles away, we live in a built up area (very urban, but no skyscrapers or anything) and sort of the other side of a slight hill, and we need to be able to use it whilst sat inside our respective flats, not hanging out of a window or anything. I want to do this for as little cash as possible and I know NOTHING about CB Radios.
Is it possible to do on the cheap? Or am I going to need transformers and massive antennae and rubbish?
Any thoughts welcome.
Ta
OpticalGhost
I would recommend buying one of thunderpole starter packs for a fraction over £100
http://www.thunderpole.co.uk/power-supp ... ocket.html
£9.99
http://www.thunderpole.co.uk/cb-radio-p ... i-881.html
(With gutter mount, you live in a flat, you can connect the gutter mount to pvc windows quite easily)
Remember when ordering to tick "add 12v cigarette lighter"
Total price £117 roughly.
Your friend will need equivalent or the same, also encourage more people in your area to do so too.
That would be everything you need, and powerful enough easily for 0.7 miles and over a slight hill. At least to get you started anyhow. Really i would say the £199 starter pack but thats a bit more complicated as you have a 20 foot aerial to fit, and i remember in the 90's climbing on flat roofs was no fun lol.
cdaw
What sort of range could someone get with this setup if the antenna is counted at ground level?
And does this radio cover all the new frequencies that were opened to CB users recently?
I've got my M6 amateur licence and also looking at other radio opportunities.
I've got a 24ft pole mounted to the shed wall with a VHF/UHF base antenna on the top.
I'd like to find a CB antenna I could attach to the pole as well just under the base antenna.
Amateur call sign: M6UCW
Uniden USC230 , Baofeng UV-5R , Yaesu FT-7900 , Icom IC-207H , CS700
Find me on GB3AL, GB3HR & GB7NS (DMR) and scanning many others
Also scanning VHF, UHF & DMR simplex frequencies
all possible fit cb antenna on a cross pole fitted to your mast and it will work well
cdaw
Does this radio cover all the new frequencies? I notice most CB radios only show channel numbers but many people talk about the various frequencies - how do you figure out what channel is linked to which frequency?
search and you will find a chart that will list all uk and mid band freq print and you are sorted
mid starts at 26.965 ends at 27.405 with jumps for radio controled aircraft
uk starts at 27.60125 and ends at 27.99125
cdaw
I have a list but how does this tie up with the channel numbers on the radio?
hobgobblin
CB Handle: Hobgobblin
If you get a multimode 10 and 11 meter rig they have either channel numbers and frequency visible on the display at the same time OR a switch on the rig to flip between channel numbers and frequency.
Good luck mate with getting a set-up. I'm an M6 ham too but still well into CB, scanning and short wave listening. I've got CB in the car and with a modulator type antenna I was talking to Vladimir in Bulgaria from here on the West Coast of Scotland yesterday afternoon.
HOBGOBBLIN
cdaw
Any suggestions of rigs and antenna's preferably those suitable for limited space or that I could attach to the pole that has my dual band antenna on top? Also something for the car as I may get better use of it then from a few view points my club uses for HF work.
