Old CB not wanting to play
sando63
Hello folks, I have only just dug my old CB out of the loft and actually remembered how much fun they were :D BUT !!
just recently I have been able to receive but not reply :( . Bin told my mike is faulty but can't just replace it with any old 4 pin mike it has to be the same make as the rig ? This must be correct because I tried my mates 4 pin mike and it did not work.....Bugger. Even bigger Bugger is I dont know the make of my rig...Oh eck. Got model numbers on the back, can anyone give me a big shove in the right direction please, Thanks Sando63 :D .
model numbers would be good as there are about 5 combinations of mike wirings on a 4 pin mike
sando63
Cheer's stampman, are these any good to ya :lol: Serial No 873237, model DW 900FM, and finally MPT 1320uk, it's all Korean to me :cry: Thanks for your reply.....PS, if you say pin No 3 and 4 need swapping over for example, which pin is which, or which is 3 and which is 4 :D I suppose it's easy when you know how, Regard, Sando63.
Think its a KERNOW DW-900FM .
Dose it look like this - http://www.cbmuseum.nl/Engeland.htm
Post a pic of your mic as midland / Kernow have a variety of mics .
If it is the Kernow then it will most likely be wired the same as the Kernow 1100 and 5100 unless it has channel change on the mic but it looks 4 pin so so it probably wont have mic channell change ,
Loads of choice on the Thunderpoll shop - http://www.thunderpole.co.uk/cb-microphones.html
kernow where standard wired so one that fits the cybernet chassied sutch as rotel or harrier should do the job
