Firestik Firefly (4 feet long)
Vuck Roger
Gents,
just moved from the US and recently purchased a Polmar Venus, since I only use my CB when off-roading and within short range of others.
Kept my old mount - spare tyre location and coax - that was all running perfectly with previous setting; got SWR readings of less than 1.5.
Just measured twice and SWR is in red-zone!
Now the questions are:
1) should my antenna be working fine?
2) is there such thing as a antenna required for the FM band in the UK?
3) could this be the radio?
Finally, in or around Berkshire where would you recommend I have this checked?
Appreciated the help!
no its possibly set up for the USA am band should be tunable with a bit of jigary pokery
Vuck Roger
Great!
Can you elaborate on the "jigary pokery" bit, please.
Appreciated!
The SWR should be similat to your USA swr if you use the EU 40 to check it , I think the Patch Lead or coax has a short or possably poor earth at the antenna mount .
read the swr meter and if its higher on 40 than 1 then if its toe old type of fire stick you have to cut the antenna wire that is coiled round the stick if its the new type the screw in or out the threaded bolt at the top of the stick under the cover
Vuck Roger
Thanks!
I will try ground the antenna mount a bit better; otherwise, next stop will be to put to antenna under the knife and start clipping part of the copper wire.
I do not believe the coax as a short, but I will consider it, if after ground stays the same!
Thank you all for your help.
