Anyone have or point me in right direction to get a wiring diagram for the mic?
searching all over (tried the likes of http://www.servicedocs.com/ etc and a lot of googling)
tried looking for midland website but only USA one comes up
anyone any ideas?
thanks in advance
Midland 248XL
thanks dragonfly, do you have anything with the colours on? or are they all different?
seems to have two black wires, one which I'm told might not be black underneath. two wires have come away from the soldering, looks as though the wire tensioner near the plug hasn't been doing its job
what color wires do you have in your mic .
I only have a Midland 78 plus and its wired
1 green
2 yellow
3 red
4 black
5 braid
6 unused
To make the cable clamp a tight fit i usually snip a small piece off a zip tie and slide it in alongside the cable then
tighten the clamp onto both .
1 green
2 yellow
3 red
4 black
5 braid
6 unused
1)yellow
2)blue
3&4 come undone and red and another black wire are loose
5)black
6)white
i was thinking of that or similar, cable insulation or similar. odd that the factory fit doesnt do a sufficient job. it doesnt help that the coiled cable isnt long enough, its mounted the back of cubby box in my 90 and even to drivers seat it struggles. i have pulled the coil a few times holding the other end to avoid it pulling at the plug, but it always recoils to that short distance after a while, depends how hot/cold weather is(as strange as that sounds)
2)blue
5)black
6)white
