poundage/mic check..
jamieradio
many moons ago when i had a cb (small mobile 40ch midland thing)
i used to be ask or heared people asking for a mic check or whatever it was called, cant really remember.
what do you need to read the poundage of an rx signal and do some rigs come with them already?.
and is there some sort of chart for modulation quality and signaly strength?.. if you get what i mean???.
thanks, jamie.
you need a signal meter which some rigs come with but as the settings on the meter vary and there is no standard the if you can hear someone that is all that matters ham radio users did use to have a standered set of readings but those are on set that cost the earth with cb you just wing it i personally give fruite machine readings ie two bells and a cherry or three oranges seem to work
