a couple of years ago i took down my silver rod antenna and managed to break off one of the ground planes.. so i broke the rest of them off..
no that i have decided to put the antenna so i thought about replacing the ground planes, so i bought some aluminium from B&Q and made up some of my own..
is there supposed to be any particular length on them or any certain amount?.
i carried on regardless, and decided to put four ground planes on.
would this be o.k?..
the reason i used four was because i bought two lengths of alu tube and vut them in half and put a little bend in them to resemble the three that were already there..
ground planes..
jamieradio
here is how it looks.
with a bit of luck it should work better than standard, but i have had this antenna since i was about 13, i am now 24.
11 years old then..lol.
i used 2nd hand t&k brackets which i obtaind from a satelite shop down the road for a fiver, mounted a 8` pole to them and then the antenna to that..
there is no rig at the moment as you may have heared, i bought a dud one from ebay... ah well, these things happen.
jamieradio
no, im not doing that every time the batterys run out.stampman wrote:and set date on camara as well
