High see readings
Balertwine
I removed my cb and siro antenna from my truck to fit I to newer model. I wired up to the same connections as some of my colleagues only to find out later that it was a 24v connection. The fuse had blown on the live wire by this time, but the cb lit up. I then bought a24v dropper and wired through this, the swr readings were 3 plus on both 1 and 40.... I earthed the guttermount, bought new anttena's but still high readings. I took my cb to a guy who tested it at his home and it worked fine. I then bought a magmount from him and tried that, the readings were even higher. The latest is I removed the cb, wired a cigar plug and tried that. The swr readings are now off the scale. I tried to earth the cb direct to the truck body, but it wouldn't even light up when I tried this. I am at my wits end, do you have any recommendations??? Midland Alan cb.
is it a 12/24 volt radio if not the cb needs looking at as the cig lighter in a truck is 24 volt and its possable a transistor in the transformer circ has blown
Balertwine
The cb is 12v, the connection. I tried it connecting to 12v cigar point.
in a truck the cog lighter is 24v unless someone has wired it to the 12v dropper in the waggon manufacture's always wire them to 24volt
Balertwine
Still got the high readings, but CB working good. Hearing my mates miles away, using a small (other company) cb.
AppleTree
CB Handle: Uncle Bulgaria
stampman wrote: ↑Fri Jan 12, 2018 8:15 am in a truck the cog lighter is 24v unless someone has wired it to the 12v dropper in the waggon manufacture's always wire them to 24volt
Not always true, they come with both 12 and 24v sockets nowadays.
Balertwine wrote: ↑Mon Jan 15, 2018 8:22 pm Still got the high readings, but CB working good. Hearing my mates miles away, using a small (other company) cb.
You can try a different meter incase your one is not working properly.
If I was you I would start again from the start. Remove the cable and run a new cable, new PL259's as well.
Or 145.500 FM 8-)
