hi
I have a similarish question to lemon.
I am a cber of the old days and I remember a bit about it although things have changed somewhat.
anyhow my question is I need to position a homebase aerial but I can't have a dipole so I have tried an Excalibur which I found to be not very good.so now on recommendation I have gone for the boomerang.
I have 2 choices mount in the attic or outside on the side of a shed.i know being outside is the best option but the shed is of course lower than the roof space.which of the 2 would give me the best reception ?
thanks for your help guys.
which position for best results
- wildfire
- CB Handle: wildfire.
Hi Tom
a bit of a dilemma isn't it matey we'll let's think again it depends on your location if your in a build in area with high buildings hills ect then the 1/4 Antenna boomerang is for you & will need to be on the wall high up bedroom window balcony ect,
but hopefully you don't have that problem then I would go for the 5/8 wave boomerang shorter than the 1/4 & works extremely well are you ready buddy ?
let's do this
pick a wall in your attic attach the following pole to the centre of your wall,
https://www.thunderpole.co.uk/homebase- ... t-kit.html
then attach your 5/8 wave boomerang to the pole them I'm sure you know the rest buddy coax from your antenna to your swr meter then patch lead from swr meter into your radio sigh then your good to go if your swr is very low buddy
