hi all
A place for new members to say hello
Cr500kev
hi all
newbie here
just got into radio scanning
got myself a whistler trx1
and a aor dv1
listen to a fair bit of cb n fancy sum of that
i have just purchased an antron 99 with the thunderpole antron top section upgrade
purchased zetagi b550p amp
mydel mp 60 amp power supply
now the question is the cb radio i have been reccomended to get the superstar 6900
but its the power output seems too high for the input on the amp it says on amp input 1-10w am /1-20w ssb
the 6900 output is a lot more than that
any reccomendations on radios as good asthe 6900 or better with low output
any info be appreciated
welcome kev :D
RSGB280662
Good afternoon Kev
You should have no problem with your rig as the manufacturers blub states that "they pump out a generous amount of power too, thanks to a couple of IRF520 MOSFET finals (which, BTW, are dirt cheap). The manufacturer claims the output to be 40 Watts on FM and SSB, and about 12 Watts carrier on AM/CW, all adjustable. " there you go you can adjust the output power to suite your needs.
73 Dennis
