dear CB radio enthusiasts
I am 79 now and hold the Ham call G3SBI and was a professional electronic engineer.You can find out more about me on QRZ.com.
You may find it surprising BUT at the moment there is more SSB activity between 27.2 and 27.6 MHz than there is on the 10M band.
Yesterday I heard CB stations from spain france italy AND brasil and nicaragua !
I recently bought a president mackinley eu an interesting radio Beacuse it has an inbuilt switch mode voltage regulator so that the rig will work from a 12volt to a 24 volt supply.This makes it ideal for portable use to be driven from a 20v lithium cordless tool battery £20 for 20v 2Ah unit from aldi.Lithium batteries are ideal for driving an SSB transmitter because their low series resistance can deliver high peak currents and of course the average power taken by an SSB transmission is quite low so a few hours operation can be obtained from a single charge.
I modified my set by cutting a white internal wire and moving across the jumper next to it to get 24.8 to 30MHz operation with the output power increased to 22W PEP.
All that is needed now is for someone to design a100W burner with a similar inbuilt voltage regulator.
When CB was first legal in the UK nobody wanted to buy the sets and I modified one for 29MHz FM.The antenna on my car was a home made shorter version of the DV27 which is a top loaded antenna.i was talking to a guy who was on his way to work at kidsgrove and he had reached the car park and was in a traffic jam in warrington. he had been using a base loaded whip I told him that top loaded antennas are more efficient and it just happened he had a DV27 in the boot and when he put it on his signal went up 3 S units.
you dont get something for nothing as a top loaded antenna has a narrower bandwidth
have fun
colin
