I've got a mini Springer antenna. SWR is 2 on channel 40 and Channel 1 is 1.5. So I need to shorten antenna. It is sitting at its lower point on the adjusting allen key screw. I need to cut my antenna down a little bit.
My question is do I cut a bit from the end tip or at the bottom where it fits into adjusting screw???
Shortening antenna
- Blue Lagoon 22
- CB Handle: Blue Lagoon
Help, I'm still learning
I've always trimmed from the base end, as the top often has a static dissipation ball on top or as with the K40, a radiused upper end.
Do you have a multimeter? Test the continuity of the coax shield by measuring the resistance between the pl outer casing and the car body. It should be close to 0 ohms. If not, revisit the mount and make sure the base is well earthed.
As your swr appears to be not far out, only take very small amounts. Ideally see how much adjustment you have, then remove a little less than half that amount and try it. Less chance of taking too much.
One person in ten understands binary. The other one doesn't.
- Blue Lagoon 22
Thanks for the above will let you know how I get on.
- Blue Lagoon 22
Thanks for your offer of help. I'm in Kingston, not a million miles away. We could meet half way I guess.
I'll give you a shout if I'm stuck.
- Blue Lagoon 22
I've had another play about with antenna. Now got an swr of 2 on channel 1 and 1.5 on channel 40.
I cant seem to improve on that whatever I do with shortening antenna or not.
I cant get any reception just a continuing hissing noise which is driving me nuts!
I'm at a total loss on what to do next.
Any advice much appreciated
Mini Springers - in my opinion - aren't fantastic but the do the job. Unfortunately there's no substitute for workable length in an antenna.
The thought occurs, is it a coloured style? If so, make sure the threads on the bottom of the coil are clear of any colour coating ie. a good electrical connection. Also, the whip into the top of the coil needs to be coating free too.
If you are hovering between 1.5 and 2, then 2 and 1.5 you may just have to go backwards and forwards and settle for a 1.6 or 1.7 maybe across the board.
The lack of receive could be that there's just very little activity in your area, or if it's built up around you there is a huge amount of static and spurious emissions to suppress middle distance reception. Is the rig supply hard wired to the battery, via the acc. line on the key, or on a lighter plug?
A nice drive out from your location is Box Hill near Dorking, or maybe the Hogs Back on the A31, both good height, reasonably electrically quiet for testing purposes, and if all else fails, a nice view and a picnic spot.
Don't loose faith, these things are a real 'dark art' which can be infuriating when it goes wrong but very satisfying when you get it right. If you can master it, please pass on how!
- Blue Lagoon 22
Many thanks for your reply
My mini Springer antenna is a standard black one. So don't think that should cause me any problems?
I've connected power supply through cigarette lighter plug.
I usually test my swr readings at Epsom Downs near the race course - nice open area. I know Box Hill and Hogs Back, maybe worth a try in the future. Reckon Hogs Back is more open than Box Hill.
Getting this sorted is infuriating to say the least. But I'm determined to get it working at some point soon I hope!
- Blue Lagoon 22
Will update when/if I get any joy.
The black could still be a coating. Have a close look at the threads to see if any has come off while fitting and removing.
The plug-in power source isn't ideal as it's another point where interference and static can run along the power lead. My VW has a can-bus system on it and as I have a, no idea how it works, and b, don't want to back feed any spurious rf anywhere it shouldn't, so it is hard wired direct (via a fuse!) to the battery. The P38 is a bit more lax so that is on the acc line on the key. It all comes down to whatever is best for you.
It's the nature of the beast that it's close to impossible to teat these things without a known contact to report back on progress. First thought, from Epsom you should (with some time to just listen) get some trucks somewhere on the M25 on 19.
I'm not familiar with the rig you have but it occurs that you have got in on the UK band?
- Blue Lagoon 22
Quick update.
Hey presto, seem to be getting somewhere.
Drilled hole in firewall of my car and wired CB direct
to battery via a fuse of course.
Drove around near Box Hill today and picked up
several conversations on Channel 19. Reception was
the best I've ever had, so far!
Will get another swr reading asap to see if it has
improved. At least I seem to be getting it sorted
- Blue Lagoon 22
Just listening the other day it sounded like they were in Sussex somewhere.
I'm out and about this weekend and up in Yorkshire next week so will have plenty of time to hopefully have a conversation with someone.
Cheers for now.
Cheers for now.
If you are out and about, this map scrolled and zoomed to find allsorts of high ground...
https://en-gb.topographic-map.com/maps/b9/England/
