Trip to Yorkshire was great, if not a tad too hot! But CB use was pretty disappointing. SWR in channel 1 is 1.5, channel 40 is 2. Antenna is at its lowest mounting point of adjustment apart from cutting it to make it shorter which I'm not keen on doing.
Reception seems to come and go. On channel 19 I hear some bits of conversation but it seems to fade away. I've not been able to strike up a conversation with anybody on any channel. I ask if there is anybody out there and give my handle but get no response at all.
All frustrating really. I'm at a loss what to do next?
Is my antenna up to the job I ask myself???
Shortening antenna
- Blue Lagoon 22
- CB Handle: Blue Lagoon
Help, I'm still learning
One of the many steps is having confidence in your setup.
When you've a known working system and there's no activity, you just shrug and accept it's a quiet night or there's no-one around your location.
But it's infuriating when you just don't know.
Sad part is, I've got to the stage where I switch on, adjust the squelch, and by the tone and level of the static know if something's amiss!
Check your inbox, PM sent.
One person in ten understands binary. The other one doesn't.
- Blue Lagoon 22
Thanks for reply. My inbox is empty:(
- Blue Lagoon 22
Nice pictures, makes my little T600 look very basic. Saying that I've treated my set up to 5ft antenna from Thunderpole. I'm currently up at Epsom Downs having a conversation with several people.
SWR reading of just over 1 on both channel 1 and 40.
Nowt wrong with a less complicated rig. Far less to go wrong - believe me! The radios will (should!) be built to a recognised standard albeit the original MPT1320/21 from the 1980s, or the multimode CEPT system so unless it's a handset or walkie talkie type, the output, modulation and frequencies should all be much the same, the result being that apart from possible reliability or build quality issues, what comes out the back shouldn't really vary. Spending more money gets you more bells and whistles but the performance won't deviate much.
The only thing that can really affect the operation is the antenna system and as you have discovered, the extra radiating length can make a world of difference.
- Blue Lagoon 22
Couldn't agree more, power to my antenna
today
it made one hell of a difference!!
today
- Blue Lagoon 22
Thunderpole Orbitor HD
Great stuff, keep it going.
I'm not familiar with the Thunderpole version of these, but experience with others suggests keeping a regular check on the security of the adjustment screw. If you give it a good 'twang' the spring recoil can work a bit like a bull whip and fire the top out.
We fit similar to tractors and 4x4s a lot and although they are the best there is in this sort of application we've lost a fair few whips through this effect. That said, they are 'almost indestructible' and if I had to say there was a weakness then this is probably it. The issue is, as with almost every antenna out there, the whip is convex in section as is the tip of the grub so the contact area is miniscule, the difference being of course that only these have the huge twangy spring! As long as you keep the grub and the mount tight you shouldn't have any problems.
Fyi... we now get around this by...
Tune the whip.
Wrap a piece of tape around the whip to mark how far it drops into the coil.
Remove the whip, hold it alongside the socket then using a marker pen mark where the grub would contact the whip.
Using a fine file (chainsaw file is ideal) put a little groove or a flat spot where the grub goes, then rough up the rest of the inserted section with some emery to give it a bit more bite and reassemble. Seems to solve the problem.
Tune the whip.
- Blue Lagoon 22
Hi, unfortunately most of the time all I get is hiss and crackle. I've had a few conversations here and there.
Not to worry I'll play about with it when time allows.
It can be very random, I usually switch on 19 when I'm on the road. Somedays you hear nothing, other days there can be quite a bit going on, there's no pattern to it. It's just dammed infuriating!
As I read somewhere recently, if everyone is listening, waiting for someone else to speak how can we know how many are actually is out there?
