Transit connect LWB van (2005) using a tri-mag mount, with Sirio 3000 and baby Midland 77-104 UK 27/81. I decided to SWR the new mount and antenna, as you do, and found that it was higher on channel 1 than 40. So, whip needed to be lengthened. By the time I had finished, i had got a really good, very low SWR, but I had extended the whip it to its maximum! (Quite a way - nearly 2 inches possibly) But It is still gripped by both grub screws - just. This just seems a bit odd to me. I rechecked the SWR on two other (cheaper) meters, and it was basically the same reading. Any thoughts? Also, the power reading on my Avair AV-201 is reading about 5 1/2 - 6 Watts across the band. The CB has been realigned and serviced professionally, and the power output is the correct 4W. I'm very confused. Is this normal behaviour? Or is it just a crap meter?
Cheers for any help or reassurance as ever people,
Chris.
