Strengthening a vertical thunderpole 5/8
Revomikey
Hi guys, I'm about to put my thunderpole 5/8 up permanently on some t and k brackets but before I do I thought I should do the bamboo internal support mod to limit bending.
I picked up some plastic bamboo sticks to insert them then I realised they were plastic covered steel, do you think this will affect the swr having internal plastic coated metal within the tubes of the antenna?
I don't want to spend a day fiddling if it doesn't work. What's your thoughts guys?
Mike
Revomikey
Update.
It doesn't matter, I installed the plastic coated metal tubes inside the antenna and the swr stayed the same. Magic. I had the ultimate 1.0 swr.
Pushing my luck I took my thunderpole off it's temporary mounting and fitted it on t and k brackets on the side of my garage on a 3m pole.
Annoyingly my perfect swr went up to 1.4 to 1.5. Still great, not perfect but it can stay there, just moving it a few inches added to the swr.
1.4 - 1.5 won't cause any problems though
good job :D
