Hi Signal reading
1. Mount the antenna high. Ideally above the house.
2. Switch to RG8 or RG213 coax.
3. Use a conventional psu not a switched mode type.
4. Is your computer near your rig?
5. Any other sources nearby like lights,plasma tvs etc.
6. Do you have a good swr? Poor swr may mean a back earth connection or the dc shunt in the antenna is u/s.
7. Look around outside. Things like arc welders etc wont help.
8. Is your rig been screwdrivered. Try a different rig.
9. Does it clear at night? Its not skip?
10. Any new masts nearby. Tetra can be nasty on the higher freq.
11. If you can try a high quality (ham type) bandpass filter.
