1/2 wave SWR
DIGGER
I've just purchased a homebase radio and a thunderpole 1/2 wave antenna. What is the Procedure for setting the SWR.
I understand a take a reading on CEPT 40 and UK 1, making sure both readings are as close to 1 as possible (1.5 been ideal)
My SWR meter has a dial though that when turned moves the needle? This is what confuses me?
I am completely new to all this so in lame terms please :oops:
set the sections together to the marks on the sections but on the bottom one push in to about 6 and 1/2 inches and the swr should be close enough the needle will move on the swr meter as this is how you read it put on fwd and alter needle to the set mark at the end of the red scale switch to rev and read off the setting hope this helps
DIGGER
Cheers Stampman prompt reply. Will investigate further when I return home :)
no problem just take your time and you will sort it ok
DIGGER
OK... I am home this weekend. Connected the radio with 20m of cable, the SWR is showing almost 5!
I will try tomorrow in daylight with the SWR meter nearer the antena. Should be able to get it lower surely.
YEP IF ITS HIGHER ON CH40 THAN 1 THEN SHORTEN ANTENNA
:D :D :D :D :D :D :D :D
DIGGER
been messing around all evening! turns out there's a short in the coax, so cut 1ft off, cleaned out the old solder of the plug...
had enough trying to soulder the bleedin thing back on!
at least it kept u amused and off the brown bottles
Photoguy2910
And at least you know where one of the problems was, should be easy to fix now ;)
108TM999
DIGGER
Discussions are on going about mouting the antenna more permanately.
I think it's a great idea.
Dad thinks it's too, but he thinks he will be working alot to get it mounted on the house.
Mum thinks good no wires down my garden. But it will look gastly stuck on the back of the house!
So any suggestions welcome. I have the mounting kit from Thunderpole, it's simple and effective, but it is a little large for mothers liking?
I nor my dad fancy climbing up the roof to mount it on the chimney, and we also have it full of TV arials!
