Quality Radio
- EarthWormJim
you need to back the echo knob off a bit on the ES 880
Jim,
2H4OW
M3OJP
2H4OW
M3OJP
- wildfire
- CB Handle: wildfire.
this is why they call 40uk the muppet band there are deccent people out there useing uk40 and with some muppets at least hearing muppets on the uk40 band is a good thing it means your equipment is working even tho most muppets are home bases and should be sat on channel 14 and not 19 because channel 14 is surposed to be only for home bases amd channel 19 is for truckers or it used to be,Bodger wrote:I have put my Albrecht back in my truck I am fed up of just listening to the Muppets on UK40.....![]()
alternatives are a uk40 with midband or as you already have one a sidebander even tho sidebanders are illegal in this country i personaly think that this country is just behinde the times compared with other countrys and i think the advandage with been on a sidebander is your able to speak and listen to other people in other countrys in europe also have a personal chat with out getting Interrupted.
- EarthWormJim
My dad used to run a hy gain v and a 100 watt burner in his volvo F10
Jim,
2H4OW
M3OJP
2H4OW
M3OJP
