Max CB Radio Power Output
tobyw7
I'm new on here (:
Ok, so the max legal power output in the UK is 4W.. but what would happen if I were to use a power amp.. ?
I mean most people don't seem to mind, as long as you don't cause interfrerence..
Just wondering what the general thoughts are regarding this.
Obviously all the people who are DX'ing into Europe aren't using 4W, right? ?
--Toby //
Bodger
There are lots of amps (burners) on the market from 25 watt to several hundred watt. It all really depends on how far you want to get out and are you mobile or static...... :?:
10 - 10 and 10 - 65...........
tobyw7
Thanks for your reply,,
I would look at using a homebase set-up for any long distance work.. I've got a mobile rig at the minute, but will get an antenna on the side of the house or in the attic. -- > ( Any suggestions RE a suitable antenna ? )
I would like to work a few countries on the continent, possibly France, Germany, Holland ?.. I wouldn't mind going further afield but I guess this could be affected by terrain, power, propagation etc..
Bodger
I don't know much about home base CBs but I would think with a good well positioned Ariel and a 2 or 3 hundred watt burner you should do just fine.... :|
tobyw7
Okay mate thanks for your help.. I'll take a look around for a burner and will post back on this topic when i get any further..
Bodger
Try the home base section on this forum.....
:wink:
antron 99 for home base but use power when mobile static not from home as it is odds on you will cause interferance with that kind of power
tobyw7
That looks like a pretty good antenna, thanks for pointing that out.
I'm going to head over to the homebase section on this forum now and ask about getting another radio..
as I've got a Team ME4 very basic mobile radio, which i would like to replace with something more serious
