Hi, I have a Uniace 100, is it possible to remove the face plate, cut all the wires and then rejoin them about 4ft longer, in effect make a remote head unit, or would it mess up the cb?
Also, if you were buying a cb, would you buy a midland 48, president walker or tti tcb 880? Any others you would reccomend, no 1. requirement is PA, no 2. is it must be as small as possible.
Many Thanks
Andrew
Can I make a CB?
Photoguy2910
- Official CB Nut
I have a Midland 48 Excel, seems to be a good radio, haven't used the others though, on saying that, I can't find the PA on it.
Might be worth picking up an ond (cheep) radio and trying to move the face, that way if it doesn't work, at least you haven't killed your good rig.
This would be an interesting mod.
Looking at an old chassis i think your gonna have to remove the channel selector first.Desoldering very carefully.
The mikes on the side so this aint a problem.
The Volume and squelch should really use screened cable.
The extended channel selector should be ok but if you get problems filter the lines with a couple of mini inductors to take the noise of the lines.
Incidently if your going the whole hog and its a big mod even for a engineer you could also stick in the fcc's by adding another PLL chip.
TC9106 rings a bell and I could give you one if i have any left. This will give you ch1 to ch40 FCC.(the chips are probably 20years old if they are still in my loft but if i find them you can have one).
Easy mod just switch PD.
