pre -tuned SWR
- lost sheep
i was reading that the ORBITOR is pre-tuned ?? i have 1 do i still need to SWR it?? jist call me thick lol
rodgy dodgy kamone!
Paul (2H3CK)
Hi Rodgy,
Basically pre-tuned means that it tuned at the factory on the test bench with a perfect groundplane. Assuming that the mount you are using is working properly and the cab you are attaching the mount and twig to is a good and solidly grounded to the chassis you should have ne problem.
Most of these that i have used have an SWR of around 1:1.5 or there abouts but its still worth checking with a meter.
Hope this helps....Cheers....P
All the best.....73....P
