Baffled :-s
DIGGER
I am baffled.
I have got my antenna 1/2 Wave thunderpole, errected on the exterier of the house, 10m coax to the radio.
I cannot seem to get the SWR below 3 :?
It's on the exterier rear wall, attached using T & K bracket kit. (from the home base starter kit)
Any Idea's what I could be doing wrong???
iguess you have the bracket connected to a pole with the antenna fixed to that antenna joints put into the marks and the bottomjoint should be in about 6 and 1/2 inches
:D :D :D :D :D :D :D :D
DIGGER
correct. All the joints are at the required length.
I adjusted the bottom one all over the place with little or no change.
I will take a photo of my antenna shortly and post that
could be bad earth or coax
DIGGER
Bad earth :?:
Educate me please :?
the outer of the coax is not makeing good connection to a resonable amount of meatal work
