Setting up help required
Dick
Hi All,
I fitted by CB last weekend and was unable to receive (apart from a couple of times I got a faint pick up) or transmit. I purchased all the gear from thunderpole and they suggested to check that the radio and antenna are working OK with an SWR . I purchased an SWR meter and followed instructions. The reading goes off the scale, tried lengthening and this did not work so before I start cutting bits of the antenna does anybody have any idea as to what the problem might be and how I can fix it? The equipment I have is a President Johnston 11 with a Trucker 80 antenaa with a quick disconnect. The antenna is fixed to a bracket at the back of my freelander.
I hope you can help,
Dick. Edinburgh.
Thank you to all who helped with the above. There was a short in the co ax cable. I purchased a mag mount here in Edinburgh which has got me up and running.
Regards. Dick. (sunny Edinburgh.)
Apbuild
Dick,
Make sure that you have the rig set to the band 'U' and that you have the 'UK' setting selected.
This is selected by using the button marked am/fm. Press it once and don't hold it down or you will set the radio to 'local' and only be able to recieve the strongest local signals.
Hope this sorts you out mate.
Rob.
You got Eclipse coming at you!!!!!
I'd rather be mud pluggin, fishin', or shootin! (Or on my CB Radio)!
jdo330
Hi Dick,
From my experience the Trucker 80 doesnt usually need a lot of adjustment out the pack as long as you have a good ground plane. Try the swr without the quick disconnect and see if it changes. If not are you able to try a different location on your vehicle, one that might have a better ground?
ATB, Jon.
Dick
Apbuild wrote:Dick,
Rob.
Hi Rob,
thanks for the info. I tried all you said but the reading is still off the scale. I will try what Jon has suggested and let you all know how I get on. Thanks! Dick.
Dick
jdo330 wrote:Hi Dick,
ATB, Jon.
Hi Jon,
no change without quick disconnect, can't move antenna location as the bracket I have is made for freelanders CB fittings of antenna. Fitted on with spare wheel and rises well up back window. You can view on e-bay.
Keep watching this space, Cheers Dick.
hotmetal1000
Check your connections on the coax for a short using a multimeter. Core wire shorting to sheilding wires will give a swr off the scale.
sounds like a short on the coax or the mount
:D :D :D :D :D :D :D :D
hotmetal1000
If you can't find anything wrong and the swr is of the scale like you say it is, I'd drop around to Thunderpole, assuming you live close to them, and ask them nicely to have a look at it for you before you start cutting bits of the Antenna. :wink:
jdo330
Hi Dick,
Is the coil of the antenna above the roofline ie, away from any solid objects? I have tried them on 4x4's in front of the A pillar / front creen and found the swr to be hard / if not impossible to adjust. TP also do a Trucker 80 with a centre loaded coil. This might be more suitable for your needs (thats what we did on my friends vehicle and it was much better).
ATB, Jon.
make sure the swr meter is in line the right way with tran going to the cb just a thought
