What would be a decent handheld CB to go for, second hand, to work in conjunction with a mobile rig...
Not looking to spend a great deal ,so doesnt need to be too fancy. As long as I can communicate between the handheld and the mobile unit ok...
Anybody have any experience with any of these :
Midland Deluxe Ready Rescue 40-Channel CB Transciever
Model 77-9145
Snap-on Battery Pack for Walkie Talkie or Portable Operation Hand Held Carring Case
12-volt DC Power Cord with Cigarette Lighter Adaptor
Polyproplene HArd Carrying Case for Storage
Two-Way Antenna System Flexible Antenna Screws Directly onto Unit or onto Magnetic Base for Mobile use
Instant Emergency Channel 9 Memory
Hihg/Low Power Switch
Battery-Low Indicator...
Handheld Eurosonic 40 channel CB Radio...
Harvard 410T hand held cb 27/81...
Regards
Handheld CB Choice... Thoughts ?
randombod
- CB Handle: randombod
that depends on the power out put of the unit, i have found they are not as good as a base set up but then again i expected that , i got a couple of miles in mine in adverage terain
- wildfire
- CB Handle: wildfire.
i was just thinking about a radio like this one as you can fit a mobile antenna to be used giving you a much greater range and here is the link,
http://www.thunderpole.co.uk/midland_42_plus.htm
