Wilson 1000
Bodger
I have had a Wilson 1000 for about 3 years, can they wear out :?: I seem to have lost a lot of its receiving ability. My SWR is about 1.7. Any suggestions guy's.. :?:
10 - 10 and 10 - 65...........
wilson 1000 do not wear out clean the mounting if you have changed motors then the whip can be too short also the recieve very well in fact better than the std antenna so check for interferance from the motor ie: dropper ,altinator or even fridge
Bodger
I will give it a good clean, see if that helps.....
whats swr at 1 and 40 if higher on 1 then you need a longer whip
Bodger
Problem sorted, the Ariel had been moved so that the mag mount was not flat on the roof of the cab.. Must remember to check it after every service..............
:roll: :oops: :oops:
easy that was a starter for 10 next question please
Bodger
The Wilson 1000 is probably the best mobile Ariel on the market, not cheap but you only get what you pay for...
fatfinger
Official CB Legend!!!
you get what you pay for in this life mate
and you dont get nowt for free
i get a tax bill for free
Bodger
A few months ago I bought a Sirio 3000 to replace my ageing Wilson 1000, but after using the Sirio for only one day I put the Wilson back on.
Absolutely no comparison...
:P :P :P
wilson 1000 king of the hill
:D :D :D :D :D
bub
What about the wilson 5000, anyone got info about that.
exactly same antenna as a 1000 just built a lot stronger to take a lot more power
:D :D :D :D :D :D :D :D
fatfinger
can you use a wilson 1000 on usb for mobile use and are they any good on 10m
it does 26 30 so it should be ok
correct me if im wrong
yup should be ok
