Power supply problem
m1pete
I have a Palstar PS-30 power supply, this has been running fine for about 18 months but now it is showing up a problem, the problem is the volt meter keeps droping to about 5 volts and then picks up to 12/14 volts again in a wave like patern.
Has anyone had this problem before, if so can you tell me how to fix it please.
Cheers Peter.
sounds like the regulator has is giving up and retireing
:D :D :D :D :D :D :D :D :D
