channel 40 swr?
Apbuild
Probably been asked before and for that I apologise.
I have fitted my recently repaired Midland 98 into my works van, and fitted the trucker 80 through the roof with a dome mount.
Although I am able to SWR on channel one and get a 1:1.7 reading, I cannot even get to the 'set' position on channel 40, even with the dial hard round to the right, although when switched over to 'ref' the needle falls to about 1:1.3. :?
What could cause this guy's.
Cheers,
Rob.
You got Eclipse coming at you!!!!!
I'd rather be mud pluggin, fishin', or shootin! (Or on my CB Radio)!
Radio one
Hi
If you can't reach the set mark then you have to check the following.
1. Have the RF power output of the radio checked on the following channels. Ch1 Ch20 Ch40. If someones messed about with the Rf output stage of the radio the power may not be even across the band.
Check it into a 50 ohm load.
2. Try a different VSWR meter.
3. Check the earth on the antenna base these can cause weird problems.
4. Avoid chopping the antenna until you ruled out the above.
Joe
sounds like uneven power and low power at that get the rig checked by the repair guy
Apbuild
TX is shown at full power on the scale on channels 1-29.
From channel 30 -40 the TX decreases in power.
Do I need to send the rig back to be looked at again?
It was repaired not too long ago.
Rob.
yes send it back to get it put right should be F.O.C
:D :D :D :D :D :D :D :D
Radio one
I take it power was checked going into a load?
If it was checked into an antenna this will affect your results.
doubt if it would affect it to sutch an extent as to total lose power at 1 end of the band
