I understand that my aerial needs to be calibrated to my rig. But if I have a "temporary" setup...i.e Rig not fixed and aerial with mag mount. Is it necessary for me to re-calibrate the rig/aerial evertime I remove the aerial and place in boot because I`m parked in a rough area for example... Or is it ok if I place the aerial more or less where it was previously...
cheers
Do I Need To Re-Calibrate Everytime ?
i always remove my wilson magmount when not in use
and the swr always stays the same
so you will be ok
so you will be ok
