hi tony, i am on the ssb's most sundays, there is a few around south wales, and you should be booming into devon and dorset where again there are a few out there.
just put your calls out on the 555 and thats your best bet, sundays there is a few people on.
im not out this sunday but when i am out i dx static mobile from sennybridge so we will be able to hear one and other no probs.
other than that do as you do, scan about the 555 area, not forgetting 550 as some drop to a zero once off the call channel (555)
what rig you running?
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
hi guys the ssb side of radio is very quiet at the moment ..but when the skip starts on 27.555 usb its very good but right now its not so good
its more local stuff now 30 to 70 miles away ..i just leave my radio on 555 most of the time to let it warm up and theres always a voice in the
back ground ...keep faith it will soon liven up trust me i love ssb
oh your have some good reports with the 257 i sometime use the same rig if im not using the icom.
everyone i speak to thinks the 257 is a much more expensive rig when hearing my calls. the magnum will do you proud
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
I wish i could access the SSB but unfortunately upon receiving the new mode slect switch, i then discovered that the PCB cirbcuit board that is soldered onto the rear of the switch is split in 2 and trying to get hold of this from magnum international is proving difficult.
Steve
DX The World "Check Your Band Plan"
Homebase - Magnum S-9 Nitro Export > Sirio 827
Mobile - Midland Alan 78 Plus Multi > Sirio Megwatt 4000
26 PW 353
the ssb channels are very quiet at the minute but has the weather warms up the skip will come good again its been a good while since i heard any
realy good dx ( skip )
Paul i was just thinking im sure it was about April/May last year when the EU started to break through? so fingers crossed folke
Steve
26 PW 353
