OK, so I drive a John Deere 6820 fitted with 2 yellow springers(5ft) on mirror mounts and my friend drives a Case MXU 135 with 2 red springers(5ft) also on mirror mounts. Both tractors have only had the antennas on less 6 months.
Both of us have had terrible trouble with the grub screws coming out and loosing the whips whilst on the road.
He has now moved onto using a TZ 27 and I was thinking about moving onto 2 Atoms.
Anyone got any good antennas that will stay in 1 piece for more than 6 months?
Tractor Antenna
Round Baler
- Chatter Box
- Contact:
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
theres this one witch is very good http://www.thunderpole.co.uk/wilson_1000_mag.htm but if trees are a problem it can snap so my other suggestion is this http://www.thunderpole.co.uk/super_nova.htm i know the price isnt a lot but there ment to be good this is another stinger type but the thunderpole one are ment to last for years http://www.thunderpole.co.uk/trucker80.htm
extremedave
- Chatter Box
look out for antenna that have 2 grub screws,they seem to stay in better
- killer cam
didnt know you could get them with two grub screws but roundbaler have you throught about raping a littel bit of non conductive tape so insulating tape and maybe it will stop it falling out
Round Baler
- Chatter Box
- Contact:
Thanks for the replies. I would go for the Wilson 1000 but at £99.99 its a little expensive just now, maybe with some harvest overtime money
The trucker 90 is a bit small. I need a 5ft antenna to get the range i require.
Thanks everyone.......
Round Baler
- killer cam
so what ya going for
- porky.69
YES THEY ARE REALY FOR WHAT THEY ARE ...WOULD NOT LAST LONG ON THE FARM WITH TREES AND BRANCHESRound Baler wrote:Thanks for the replies. I would go for the Wilson 1000 but at £99.99 its a little expensive just now,.
GOOD LUCK WITH WHAT YOU GO FOR
- andy@thunderpole.co.uk
- Site Admin
- Contact:
Hi Round Baler,
We have a new antenna that should be ideal
It is 100% Stainless Steel, and has reinforced parts and two grub screws to hold the whip in. In fact it was designed for situations just like yours, farmers, land rover users, etc.
There are two versions, check out the longer one here...
http://www.thunderpole.co.uk/orbitor-ss.html
Andy
Andy
- killer cam
andy i think they should be in some of the cb packs compared from the mini orbeter so you can chose a long one or a short one and there would have to be different prices
- Site Admin
- Contact:
Yep good idea Cam, we are working on it...
Andy
Andy
