Advice needed please guys!
hobgobblin
- Chatter Box
- CB Handle: Hobgobblin
Car has been in for a new set of tyres this week. When I got it back, both my Magnum 257 AND Yaesu had been messed about with....all the buttons and dials were different to how I'd left them and both radios were tuned to completely different frequencies. Now the worrying bit: I use USB on the Magnum around the 28.400Mhz bit of the 10m band and had left it tuned to the calling frequency. Also this is where the antenna is correctly tuned to with my swr being 1.5 and just under. When I switched the Magnum on after I'd got the car back it was tuned to 29.537Mhz which meant they'd done an awful lot of button pressing! Advice needed for the next question: if they've tx'd on this frequency could they have damaged my radio? My initial thoughts are yes, but am not sure how to find out. The warranty doesn't cover mis-use so do you think they should buy me a new radio?? At the moment the garage owner isn't being very cooperative!!
HOBGOBBLIN
hobgobblin
- Chatter Box
Checked the swr & pwr with my meter...all's well there! Then Saturday evening I went out to do my ham radio and the Magnum 257 is working brilliantly!! Got a 5, 7 report from my friend I had a ragchew with!!! The VX-8E is working fine too.....was doing APRS at the same time and I showed up on http://aprs.fi
HOBGOBBLIN
