ok i am fed up
padster
CB Handle: night owl
went and got a lovely old steel wheel mounted dv27 in it and put it in loft swr through the roof on channel 40 so i adjusted and it went up on channel 1 any body help ::-() ::-() ::-() ::-() ::-() ::-() ::-() ::-()
grom
You adjusted it to far :oops: shorten it again but only 3mm at a time until it comes right =D>
start with the tip about 1" out and take your time
