hi guys
well im after a amp for my cb home base rig I dont want to speed a lot of money on one plus i would like to run it from just the one power supply (one that I run the rig from 6 amp) whats the most powerful amp i can run on that and also are pre amps any good ?
amps/ pre amps
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
Kenwood man
- Good Buddy
What you need is a good antenna with a low swr first or the amp is a waste of time.
Btter still use 25w out of the radio if it does that or get a cheap hf rig that will do 100w and you can adjust the power to were you want it.
But the psu you have is of no use 6 amps is too low 7-9 to run my old lincoln and hf require 25 amp.
- killer cam
hi mate
i have a 4 watt fm uk cb radio at home my antenna is an A99 i want to get an amp to get out further i was wondering if pre amps are any good what power supply do i need ? 10amp ? iv got a 6 amp power supply for my radio but im sure i will need another power supply for the amp i take it that will need to be a 10amp just for the amp
Kenwood man
- Good Buddy
A pre amp is ONLY for the received signal it makes the guy your talking to much clearer and better quality it can make you listen to a weak station were as if you didn't have one you may not hear them very well.
A linear or booster or kicker is a simple amplifier that you put 4 watts into it to get out say 50w out to make you heard stronger.
To run either another psu (power supply unit) is needed 5-7 amp should be fine for the linear, the pre amp may work from what you have already.
Hope that clears up the differance, in a Hf rig most have a pre amp built in and variable 100w power.
- killer cam
hi mate
yes that does clear up alot of confusion thanks so do you think i should be able to run this amp: http://thunderpole.co.uk/k-po_ea150p.html on my current 6 amp 13.8v dc power supply aswell as my radio ?
Kenwood man
- Good Buddy
Yes you may just be ok no larger linear as it will draw more current 6 amp minimum 6-8 amp psu,
- killer cam
hi mate
what will happen if my 6amp power supply cant power both radio and amp ?
Kenwood man
- Good Buddy
It won't power the amp it may warble on audio as seen as your only on fm it should be ok if it was ssb you would sound crap.
Most folks have a sepperate power supply or use 20-25amp psu to work these this is what i use then you can have various things running at the same time or use a car battery for the amp but you will have to charge it every week or so.
- killer cam
ok cheers mate well i have not got a spare car battery gave one away couple months back
see i want to get a pre amp but the cash flow is low at the moment if you get me so im trying to avoid a new power supply
thanks
thanks
