Handheld Problem
peter_winkley
Hi
I'm looking for a little help with a handheld rig I recently required. It is a Realistic TRC 1005.
Basically I can recieve fine and having sorted the aerial connection it appears to be transmitting but there is no sound. When I push the button the screen switches to show tx and what appears to be a signal strength meter. Since cleaning up the aerial connection this has gone from 3 bars to 5. However with the button depressed it appears to be broadcasting a signal but not sound.
So my question is does anyone have idea what the problem could be and how can I track it down. I stripped the unit down and couldn't see any obviousdodgy connections.
Thanks in advance for your help.
Pete
is the trc not an am set ?
peter_winkley
stampman wrote:is the trc not an am set ?
Um
Its got the Cb 27/81 stamp on the front. I thought that it meant it complied with the the fm cb regulations?
Also last night I was picking up a lot of chatter on ch14 and 40, although I couldn't get a copy. I thought that am frequencies where illegal to use now?
Please excuse my ignorance its been a good few years since I used a CB at all and I didn't really have much in the way of technical understanding at the time.
no if its got the stamp then it should be uk best bet would be to try it useing a scanner so you can hear what is going out
