Hi.
I have put a post on this site, but not on this part of the forum.
I am looking for how to add 40CH to my JWR MK2.
I have had this same model of rig in the past, same board as the Icom 1040.
But it had a link to one of the pins on one of the IC's that ran to ground.
I do not know the pin the wire wen to, or what other work would need to be done.
But I am looking for help in getting the rig to do what I want it to do.
Just one more thing, the 40 CH's did NOT go up in 10KC's, but went up in only 5 KC's
Well I hope that someone can help me.
Bye from John
JWR MK 2
Amateur 10m mod for JWR M2 / Icom ICB-1050
http://www.m0ysu.com/icom1050.html
Snip from the general CB repairs page.
JWR Mk 2 - To improve squelch replace the 470R resistor besides pin 9 and 10 with a higher value.
Rig lights up but no TX/RX - Try replacing D203 (5.6 Zener diode) No TX can be caused by R327 and/or R127
Fluttering Oscillation - on both TX and RX , replace audio IC (Also ICOM)
On AM version - No Audio and RF carrier output and no modulation on TX is caused normally by the audio IC.
Low RX and TX - can be caused by a faulty Output Transistor especially in Stalker 9 type sets.
Blows Fuse - Check insulating washers and bushes on all heatsink transistors. also. obviously, check protection diode
JWR/ICOM - Fluttering oscillation on both TX/RX, replace audio IC.
Just to let you all know, I have got the other 40ch's out of my rig.
And to all that told me that it would not work, or it would take more than just 1 wire, you are all wrong
All I had to do, run a wire from pin 6 of the ic to groung, OK I did add a switch, but apart from that I have NOT had to do any other thing to it.
I still have the normal 40ch's pluss 40 more ch's but only at 5kc's apart (NOT the normal 10kc's)
PS. It is also the same board as the Icon ICB 1040 as this was NOT a 10 meter rig, only a CB, and as far as I know, the Icon 1050 is NOT a CB
