best mobile ariel
boss
CB Handle: snowman
hi what is the best mobile ariel for a lorry bearing in mind that i do alot of back road driveing so will get knocked about quite abit, low trees etc
thanks
chris9
Probably the large springer/orbitor type.
I used these on the farm tractors and are good with low sheds and trees.
And not bad performance if good groundplane and mounted high.
The tall Sirios are probably the best antenna though for performance, but the best one have a solid base, so not the best on tractors.
Biggest problem these days is the lack of groundplane on modern tractors and lorries with their plastic roofs.
Makes the antenna work much less effiecient, and SWRing can be a problem.
Chris
extremedave
the ones with 2 grub screws to hold the whip in seem a good idea and stand up to abuse better
wilson has the strongest mag or use a gutter mount what sort of motor is it
boss
CB Handle: snowman
t reg leyland daf plenty of metal problem i have is that the ariel cant go on o/s roof as air intake is there cant go in the middle as lorry gets loaded from above from a conveyor system so can easily get snaged mounted on n/s just catches everyhing going do alot of country track/road driveing :?: :?: :?:
GUTTERMOUNT over drivers door with omega 27 on it
boss
CB Handle: snowman
no gutter above door not sure if its the original cab
ok mirror mount on stay holding side panel to rear of cab
