ss gutter mount
T3 Pete
Help needed.I've just got a ss gutter mount ca'nt figer out wich part is suposed to make a good earth is it the v shapped bracket? if so do i have to remove some paint to make a good conection. tha last mount i had just had 2 grub screws that bit into the metal.
no take the plate out and the screws will bite into the metal and give you the ground connection
