ZETAGI B153
spectra
Hi all, back after a 3 year break, i,ve just set up my homebase using a cobra 19 dx 1v, zetagi b153 amp, a mercury 20amp psu and a 1/2 wave silver rod on a 20ft pole.
I have a query regarding the amp as i dont want to carry on using the amp if its faulty, when i power the amp on the red power light does not illuminate but when i crank the mike it illuminates, is this normal for the amp to work this way.
I also have a maas k-swr-222 swr/power meter and the instructions are in, i think, in german, i know how to use the swr side of it but not the power side, can someone advise please.
Thanks in advance and its nice to be back.
grease monkey
hi i dont know about the power swr meter but your zetagi amp works how it should i have two of them and they work exactly the same.
spectra
Cheers for that grease monkey, i,ve had amps before where the power light illuminates on switch on,thanks again =D>
just deleated double post to stop confusion
spectra
sorry stampman,did,nt know which section to put it in,thanks
NO PROBLEM sometimes were undecided then we become indeciseive
