Hi folks..
Has anyone out there used or is using one of these 7ft Thundersticks? I would be interested in knowing how well they work compared with other antennae such as the Sirio 4000. In 'ye olden dayes' the American made Firestik antenna's I had always had trouble tuning up on the Uk band being wound for the US part of the band. Being top loaded these antennas should 'kick arse' but before I buy one for static mobile working, is it going to be better than my Sirio 4000?
Your Wisdom please...
Bionic Budgie
Diss
Norfolk
Thunderstick 7ft Antenna,
- Bionic Budgie
- Motor Mouth!
- CB Handle: Bionic Budgie
I believe that the firestic with its top end firing tendancies will work beter as the signal is released at the top end of the antenna there by giving more hight to the transmittion ,where as a base loaded antenna like the sirio 4000 will release most of its signal in the centre of the whip,same as any dipole would.
