Can anyone help
CB RADIO GEZZA
Hi im looking to replace the A99 that i have up.what would be an ideal replacement for it!.regards
spectra
Myself, i have a 1/2 wave silver rod, works well to an extent but i,ll be replacing it with a sirio gain master which are available from Thunderpole.
26-TM-037
Sirio 827 or perhaps the new Sirio Gain Master
clockworkorange
827 baby all the way!!!!!!!! =D> =D> =D>
Donga
CB Handle: Rockape
Is the 555 chanel on AM or FM or a ssb
needle bender
hi,,27.555 is used on usb......be carefull if using from home....you will have to think up a call sign to use..or join a dx club...there are a few to be found online....mine for example is 26-ct-672...good luck hope to catch you sometime.....
