Aerial straight or angled
Rustydiver
I'm going to fit th cb into my new van over the weekend, is it ok to mount th aerial at an angle no more than 45' or straight up, was thinking about an angle as when I park the van it goes under a canapé at an angle it wont keep hitting it going in and out.
I'm using a gutter mount in the middle at the front so the cable can go up through the air vent above the front window.
Green_Laner
CB Handle: GreenLaner
straight up is the way to go, the aerial will radiate the signal out and works best pointing straight up and with nothing in it's way. What you could do is invest in a small quick-release bayonet for the antenna so you can take the whip down in a matter of seconds.
I wouldn't bother having the antenna setup on an angle 8)
correct antenna are designed to work best vertical
