I,ve Got A Little Willy....
Bionic Budgie
CB Handle: Bionic Budgie
Hi Folks...
I,ve got a little willy :oops:
Just thought 'dI tell you about a little antenna I have been testing lately.. I usually run a Wilson 1000 on the roof of my Transit and although this antenna works Superb..it does clang on every bloody branch and can get annoying. I thought I,d try the Little Wil antenna, this is the mini Wilson and stands at just over 90cms high. It only comes on a mag mount and the coil and mag-mount are all one part so its a fixed mag only install. I popped it on the roof and had to cut about 40mm off to get it to tune on the UK 40. Once tuned on channel 20 the antenna bandwidth just covers the 1 to 40. Beyond that, it goes out of tune very quickly. So if you want an antenna that works from 26 to 28 mhz, this antenna won,t cut it. The bigger wilson 1000 covers this with ease.Back to the Little Will, Once tuned I carried out tests with various stations comparing it with my Willson 1000. The 1000 was about 1 S point up..thats all!!! The rx signal was the same and for a short antenna, it works really well. I run 60 watts into it (its rated at 300watts) and the SWR stays stable. If you want a small and VERY neat antenna that works..get a Little Will. The only down side is that it is a fixed mag mount, if the coax gets damaged, I,m not sure how easy it is to replace. That said..it cost me £35.00 for a complete antenna set up,so for that money..just go and buy another. Hope this is of interest to someone out there.
Breaker Break..
Ian
Bionic Budgie
Diss 20
lol :lol: :lol: good antenna and top post
repaired one that had had 200 watts through it am melted it but as you say a good antenna for the uk 40
