Putting a silver rod up for my lad but i aint used a swr meter for years and i can't remember how to, how do i alter the swr once the aerial is in place? Plus how do i use the meter, here is a pic of one i have just bought.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1
i have seen a pic of one of these since i bought it, in the pic it had a tiny little antenna on the back of the meter, but it's mising of this one, does this matter? Plus, how do i use this damn thing?
once i have put up a silver rod, how do i alter the swr
first set the slide switch to swr second switch to fwd put cb on channel 1 and key the mic alter the slide till the needle rads set up and the end of the scale
and flip the fwd switch to the down position rd then read thee swr repeat on channel 40 if the swr is higher on 40 then slide the top section of the antenna into the lower section start with about 61/2" in and it should not be too far out good luck
