Midland 98 plus. skipping channels.
dag955
Up untill yesterday this set worked fine, it is 5 or more years old. I noticed the set started to skip channels usually down 1 or 2,then it froze none of the buttons on the mic worked i can move the channels up and down on the set itself but not on the mic. So i tryed a mic off another set and all it did was skip through all channels like it was on scan. Will not send or recive, signal was fine before all this.
sounds like a mic problem check for shorting wires in plug
I think the mic wiring will be the same as the Kernow 3100
