Hi to all, i have just purchased a ml 145 ( mag mount ) and i can,t get the swr down to the required readings stated on the instructions which are 1.1:1 on ch 1 and 1.3:1 on ch 40 ,by the way i have a maycom em 27,
the readings i am getting are 1.4 on ch 1 and 1.7 on ch 40 and thats after moving the antenna about on the roof of my astra, i got the above readings when its near the cars radio arial.
thanks stampman, i,m a bit finiky when it comes to following instructions if its says that on the label kind of thing, but if i,m getting advice from an expert and thats what i,ll stick at, 1.4 it is then i, m happy with that, cheers and all the best
It worked for me. but please only cut off 2 to 5 mm at a time. don't go crazy when chopping off bits of your antenna. Could not belive the SWR reading went so low.
the ML 145 is a great antenna as i used one what you could do to lower your SWR is not to cut the antenna as this method does not always work but i would recommend putting your antenna in the center of your roof where antennas actually should be, also will in prove with your radiation pattern a bit as well but your SWR is not all to bad as it is & if your happy as it is & if it is working alright thats the main thing.
