Set up ?
reef
CB Handle: Reef
Hi Guys installed my cobra 19 dx in my pajero with the ariel roofmounted ,cable run through car and out the rear door .
Have ordered a swr to fit inline and will tune ariel as soon as it arrives . Have the rf all the way open and squelch at just past noise level .
Now maybe im thick but here goes
when i turn squelch down i get a loud buzzing noise that disappears when suelch is applied again, however mt s/rf meter shows a good signal and a busy sign when squelch is off and the signal and busy sighn dissapear when i put the squelch back on (no noise from set at all ...
Am i doing something wrong ? i was out in the car yestareday and recieved some garbled broken signals but noone seemed to respond when i asked for signal check
HELP
i feel such a twit :oops:
Btw rig is wired to the ignition via the car radio
use swr to set up antena but then remove from from line as you lose outgoing power if left in line try differant location and see if you still get the buz make sure its not normal skip
